buffer problem?
I'd recommend adding a Time Delay between your VISA Write and your VISA Read.
Unless you've a got a really slow instrument, I'd say 500 ms is probably plenty.
Message 41 of 48
(4,046 Views)
so we tried a delay, wait, and timeout and the visa read still gives the problem. the write always sends it but the read sometimes doesn't respond. for the latest one we put a timeout of 30 sec.
Message 42 of 48
(4,036 Views)
 http://decibel.ni.com/content/docs/DOC-3960
if you can send a screen shot of this program (write, read) or have it compatible for labview 7 that would be great!
Message 43 of 48
(4,033 Views)
Ugly front panel.  Replaced a stacked sequence with a flat sequence so that you can see all the frames then cleaned up.
Lack of error wires on some GPIB functions would cause a race condition.
Bad spelling.
Message 44 of 48
(4,030 Views)
i was just wondering what the "pulse time" setting was ?
Message 45 of 48
(4,011 Views)
nevermind! just saw it on the front panel thanks!
Message 46 of 48
(4,010 Views)
are they reading any data for this program?
Message 47 of 48
(4,007 Views)
I'm having a similar problem with a Scilogex stir plate.  I am running a program to check the stir speed on the stir plate at given intervals.  Whatever interval I use, the program runs 40-150 times and then gives a timeout error, and the only way I know to fix it is to turn off and back on the stir plate.  I have the 50 ms delay suggested by Scilogex. Did you ever figure out what was causing the timeouts at random intervals?
Message 48 of 48
(3,828 Views)
