buffering of samples
I am using pci6042e for acquiring data.
can you tell me how to buffer the samples?
(3,228 Views)
Can you use the Help?
From your VI click Help
Then Find Examples
Then Hardware Input and Output
Then DAQmx
Then......depends on what you want to do
Read analog input?
Then Analog Measurements
Read Voltages?
Then Voltage... ... a lot of examples available Smiley Surprised
See if one fits your needs Smiley Wink
(3,217 Views)
This newsgroup isn't used much.
Try forums.ni.com.
You might want to say if you are using Labview
and what version and if you have looked at
any of the examples provided with Labview
which cover this topic.
(3,216 Views)
hey anonymous,
Your comments about this forum are nonsennse. The original post was made to ni.com.
(3,203 Views)
>Try forums.ni.com.
But you can also search the 64,000 posts for this group in the Usenet
archieve.
greg
(3,159 Views)
