build a cylinder to plot it in 3D plot
Hello!
Someone knows to build a cylinder to plot it in a 3D plot?
If you can post the code to do it, it would be perfect.
Thank you in advance!
Larson
(2,855 Views)
Download and install the 3D picture control  (LabVIEW 7.1). There will be an new example in the example finder that shows what you want. 🙂
(2,846 Views)
Hello!
I've tried to install it but I'm working in labview 7.0 and 3D picture control doesn't run with this labview version. I have to work with labview 7.0. Can  you send me the code or the vi's where the cylinder is built in labview 7.0?
Thank you very much
Larson
(2,839 Views)
I tried to save the "Simple 3D Objects" (Altebanch: is this vi that you were talking to?) to the previous version (7.0) and several warnings have appeared.
These warnings are appeared due to some VIs of the 3D Picture Control cannot be saved to previous version of LabVIEW (7.0).
However, I attach the vi and the warnings (txt file)
Regards
DiegoM.
altenbach
(2,803 Views)
Yes, it only works for 7.1.
(2,795 Views)
