10-13-2005 11:48 AM
10-13-2005 12:07 PM
10-13-2005 12:30 PM
Hello!
I've tried to install it but I'm working in labview 7.0 and 3D picture control doesn't run with this labview version. I have to work with labview 7.0. Can you send me the code or the vi's where the cylinder is built in labview 7.0?
Thank you very much
Larson
10-19-2005 04:21 AM
I tried to save the "Simple 3D Objects" (Altebanch: is this vi that you were talking to?) to the previous version (7.0) and several warnings have appeared.
These warnings are appeared due to some VIs of the 3D Picture Control cannot be saved to previous version of LabVIEW (7.0).
However, I attach the vi and the warnings (txt file)
Regards
DiegoM.
altenbach
10-19-2005 10:01 AM
