build table
hi ,
i have a problem in saving  data in a table , bcuz i want  "DBL 64 bit real "  to save  in a table after each run of the program , not array of data ,
(3,409 Views)
You are building an one dimension array, but you need a two dimension array
(3,399 Views)
Use the "reshape array" function to convert an 1D to 2D array
(3,398 Views)
