Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
build table
build table
ssaara
Member
11-29-2007
02:12 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
hi ,
i have a problem in saving data in a table , bcuz i want "DBL 64 bit real " to save in a table after each run of the program , not array of data ,
New مستند Microsoft Word.doc 42 KB
0
Kudos
Message
1
of 3
(3,384 Views)
Reply
Re: build table
Pnt
Active Participant
11-29-2007
03:35 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You are building an one dimension array, but you need a two dimension array
0
Kudos
Message
2
of 3
(3,374 Views)
Reply
Re: build table
Pnt
Active Participant
11-29-2007
03:41 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Use the "reshape array" function to convert an 1D to 2D array
0
Kudos
Message
3
of 3
(3,373 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
