build
When build using master vi all well    build using lvproj sub'vi's are not included
(3,768 Views)
Your post makes no sense. What is this "master vi"? Please provide more information if you expect to get help.
http://www.catb.org/~esr/faqs/smart-questions.html
(3,765 Views)
I have a program called say prog.vi inside a directory with other vi units.   When I go through the build proces using this vi all is well.    When I build using the LVproj it builds ok but does not pick up some sub.vi units
(3,757 Views)
(3,754 Views)
Accepted by sonoflo
Is there an echo in here?  🙂
If you choose prog.vi as a "Startup VI", all dependencies will be automatically included.  If you want to force something to be included, you can add the vis to the "Always Included" box.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,747 Views)
Are the subVIs called dynamically?  Dynamically called VIs will not be automatically included in your build.  Any others should.  To make sure that they are included, select "Always Include" in the build specification.  NOTE:  I believe the VIs have to be in your project to force the inclusion.
(3,740 Views)
