building application with wordsub
That is the only dynamic vi that I added, see example:
Message 11 of 14
(701 Views)
Hi Jim,
In the very specific case where your application uses type defs and control references this error may occur.
I would suggest unchecking the box labeled "Disconnect type definitions and remove unused polymorphic VI instances" under the the "Application Settings" tab of the Application Builder.
Scott Y
NI
Message 12 of 14
(688 Views)
Done that, it has been unchecked all along.
Jim
Message 13 of 14
(686 Views)
Hi Jim,
I am not aware of any other causes of this error.
Can you post a small example, including the .bld file, that demonstrates this?
Scott Y
NI
Message 14 of 14
(663 Views)
