building block diagram to control stepper motor
I am a senior mechanical engineering student and a specific part of my final project involves controlling the motion of a stepper motor in labview. The idea is that we will enter the value of a certain parameter to the software and the control system will dictate how many steps the motor should rotate in order to move a power screw mechanism to a desired position. Since we have not much experience on this subject, we are looking for guidelines or tutorials related to driving stepper motor in labview, specifically. Can anyone suggest a step-by-step tutorial which we can benefit to build the relevant block diagram in a short time? Our stepper motor is NEMA 17.
Thanks.
(4,102 Views)
Read through these links and see if any of them help. Also NEMA 17 is the physical mounting geometry specification and has nothing to do with control of the motor.
LabVIEW 2012
(4,086 Views)
I've already read through these links and I coudn't find an answer. That's why I opened a new topic. Thanks for the valuable information anyway.
(4,079 Views)
Do you have the NI motion control software and hardware? If not and depending on your budget you might consider using an Arduino. There is a LabVIEW driver for communicating with it. Also there are several stepper motor shileds you can get. A shield is an Arduino peripheral. Check out Sparkfun. If this is an industrial application with a large budget you should stick with the NI products because of the support you get. The motion control software has lots of examples to get you started.
LabVIEW 2012
(4,076 Views)
The programming depends on the controller you are using to run the motor.   If I needed a stepper motor controller, I would first consider one from Allmotion such as the EZ17, which mounts on the back of a NEMA 17 motor and is controlled by simple serial commands (eg. V1000A23000="Go to position 23000 at 1000 steps per second").
But if you already have a controller, you need to say what it is if you want help in programming it.
(4,057 Views)
LS1041 (18-50Vdc 1.4Arms 2Apk) microstep driver and arduino microcontroller
(4,015 Views)
Hello hope you are doing great!
Definitely the Motion control and motion Hardware from National Instruments are a good starting point for your application.
As our fellow member recommended this is a great link to get started with.
http://www.ni.com/motion/setup/
Luis A.
Applications Engineer.
National Instruments.
(3,985 Views)
