building executable mac mxBase question
I have a medium sized program, which used the mxBase vi's.  When I try and create an executable file, the "Copying files to application" box get about a 1/4 of the way done and lockups labview.  I tried to save the vi with "Save options" and saved it as an application disturbution.  I then added the files created from the "Save Options" as "Add support files".  This allowed the progress of the "Copying files to application" box to get about 3/4 of the way done, but still locks up LabVIEW.  I can not figure out what is happening.  I am able to create executables for all the subvi's in the program.  If I try and hold Alt+Shift and click run, to load all the vi's into memory, it locksup LabVIEW.  Anybody have any ideas?
(2,708 Views)
Hi shivels,
I think the problem is rooted in the inability to recompile the binary on the VIs (Alt+Shift and Run button). What happens when you recompile just the top-level VI (Alt and Run button)?
Also, are you working on an Intel Mac or a PowerPC Mac?
Michael K.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(2,693 Views)
