control references and XY graph
hi there,
I was wondering if somebody can help me with passing data to a " XY graph
" not waveform graph [ in a main VI ]
from a sub vI using the concept of a control reference..
p.s: I dont intend to flatten data .
It works fine with waveform graph but there is nothing to show ( even
examples ) me how to do it with XY
graph.
thanks.
ananth
(3,847 Views)
>with passing data to a " XY graph" not
>control reference..
I don't see any problems here using LabVIEW 6.0, and I'm wondering if you're
having trouble with a Variant input or something.
Here's an example of a subVI that spits data into a main VI's XY Graph by
way of a control reference:
ftp://ftp.ni.com/incoming/xy.zip
John Lum
(3,845 Views)
thanks
and you said it right. that was the problem.
"John Lum" wrote:
>>>I was wondering if somebody can help me>>with passing data to a " XY
graph" not>>waveform graph [ in a main VI ] >>from a sub vI using the concept
of a>>control reference.. >>I don't see any problems here using LabVIEW 6.0,
and I'm wondering if you're>having trouble with a Variant input or something.>>Here's
an example of a subVI that spits data into a main VI's XY Graph by>way of
a control reference:>>ftp://ftp.ni.com/incoming/xy.zip>>Regards,>John Lum>National
Instruments
(3,845 Views)
In the example, why is the control reference outside the case statement, since the graph
is only updated when plot=true the ref belongs inside or did I miss something?.
ananth wrote:
> thanks
tional
> Instruments
(3,845 Views)
That xy.zip is no longer there. Can someone post it back?
Thanks!
(3,641 Views)
Hello!  There is an example sub-VI that passes a graph to a main VI posted in this forum
Please post back if that is not what you are looking for.
Lorielle P.
(3,615 Views)
I got it working now but thanks anyway. Reference is better than globals but trickier.
(3,607 Views)
