burster 9163
I would like to know if anyone knows how to measure values from a burster 9163 using labview 8.2.
I have tried to find samples but I wasn't lucky.
Message 1 of 13
(6,939 Views)
Will this thread help you? Post back.
Message 2 of 13
(6,924 Views)
I have tried to  read the values using "Visa" but it is not working. It allways says that an error ocurred.
I am attaching the error and the Vi.
Regards
Message 3 of 13
(6,873 Views)
I did like it tells in that link, however it reads zero bytes.
I attached the picture.
Ricardo
Message 5 of 13
(6,854 Views)
see this
Also why have you used such a huge delay?
Message 6 of 13
(6,833 Views)
Have you tried using something like Hyperterminal to see if you get data coming in that way?
Are you sure about your baud rate, data bits, stop bits, and parity parity setting?
Are you sure you are using the right kind of table, whether it is a straight through or a null modem?
Is any kind of hardware handshaking required?
Do you need to send any command to it to initialize communication?
Message 7 of 13
(6,829 Views)
The serial port initialization should not be in a case structure. Why would you ever run the VI without configuring the serial port first?
There are numeous instrument drivers for Burster devices in IDNET.  My suggestion is to find a driver for an instrument that most closely matches yours and see if you can modify the code. You may also want to consider getting their "DigiVision" software. If it communicates over the serial port then you could use something like PortMon to see what commands are being sent.
Message 8 of 13
(6,821 Views)
thanks.
the huge delay was only to see if with more time it could read...
Message 9 of 13
(6,786 Views)
With the Digivision software  it works prefectly.  And from there the baud rate, data bits,..., is given.
Message 10 of 13
(6,785 Views)
