burster 9163
Have you tried looking at the other drivers? Do you have the programming manual for the instrument? What does it say as far as what you need to do? As Ravens Fan indicated, do you need to send a command to query for information, or does the device continously send out data on the serial port. Did you try HyperTerminal (if you're on Windows)?
Message 11 of 13
(1,199 Views)
rczone wrote:
thanks.
the huge delay was only to see if with more time it could read...
I dont think by adding delay ypu can do this. You can increase the timeout if required.
Message 12 of 13
(1,187 Views)
Accepted by topic author rczone
Thanks to all.
Using the Portmon software I was able to see what command the Digivion uses to inittialize the reading, and now I am alble to read it using labview.
Regards!
Message 13 of 13
(1,165 Views)
