byte operations
hi everybody
I have   established  a comunication with serial port ..it sends strings in hex ..my problem is how to convert string in hex( 2 bytes) to perform this opeartion in order to extract numbers ( the string is composed by 2 bytes AxL and AxH)
acc=((axH<<8)|axL)/32768*16
Thanks for help
(1,841 Views)
Use string-to-byte array function.
Santhosh
Soliton Technologies
(1,819 Views)
Accepted by skisim
Hi skisim,
one (of many) possible solution:
I convert to I16 because of that scaling factor of 32768, which hints for signed 16 bit data…
(1,813 Views)
