c-DAQ 9174 USB Chassis LED Status
Hello,All
I have a question about my c-DAQ 9174 USB chassis. When I start to run labVIEW to collect data, the active LED become green and start to blinking. Is it normal? Meanwhile, sometimes, when I start to run labVIEW, the active LED become solid green. Are both blinking green and solid green shown the device works fine?
Thanks.
(4,191 Views)
Hi lh,
why don't you read the manual of your device?
(Typically green lights indicate "good" conditions…)
(4,168 Views)
Hi,GerdW
Thanks. I have read the user manual before. But I did not find anything that was explained that when the active LED was blinking. Do you have some suggestions?
Thank you
(4,117 Views)
Accepted by lh6666
Hi lh,
It's on with USB traffic - and off, when there is no traffic...
(4,115 Views)
