c# executable and cvi dll interacting in LV environment
All,
         I have a large program that I have recently modified. A cvi dll is called to monitor comms (UDP) between two pieces of equipmement and is running all the time. This software is provided by a third party  without source code. I have added an executable to the labview to connect to a wifi,telnet then disconnect which works fine as stand alone, When the wifi test is called from within the main labview problem I get incorrect handles reported by the UDP comms. I have tried to reproduce this fault in a more conrtolled fashion with no success and this is the only way I can recreate. it.
I am using system exec.vi to call the wifi test and a call library function.vi to call the dll.  Is there a way to ensure these two objects dont interact with each other.
Btw ports used etc by the udp and telnet are completly seperate
Any thoughts?
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(2,318 Views)
Dear Akiel,
Thank you for your post.  I was just wondering if you had been able to make any progress on this or have managed to find a work around?  If not then I can have a look into if it.  Is it possible for you to upload any code/ DLLs / screenshots that may help resolve the issue you have been having?
Kind Regards,
Robert Ward
Applications Engineer, NI
(2,237 Views)
