cDAQ 9174, Module 9226, LV 2014.
I am currently trying to run the 9226 module for reading RTD's. I am getting a Unsupported Module message in MAX for this module. I found out that 9226 isn't supported by DAQmx 14. But it will work with 18.1. But I can not get 18.1 with LV2014. Is there anything I can do as a work around for this issue other than getting a new version of LV? Thanks.
(2,334 Views)
Accepted by AELCA
This says that it's supported in 17.6, which does work with LV2014.  You should be able to use the version selector to download that version here.
(2,318 Views)
That worked! Thanks!
(2,176 Views)
