cRIO-9045 Software install issue getting through firewall
The software install process on my 9045 is stuck at the "Offline target installation" step (see attached SC).  I've created inbound and outbound rules for the specified port but I'm still getting "Failed to open the specified port in the firewall".
Another thing I noticed.....MAX specifies the protocol to be HTTP but when making the firewall rule, HTTP is not a protocol choice.  I picked TCP.  Tried UDP as well with the same results.
Any ideas on what I could be doing wrong?
Thanks!
(725 Views)
Try the info in What Ports Do I Need to Open on My Firewall for Communicating with CompactRIO?
https://tmesystems.net/
(683 Views)
