cRIO 9067 Chassis Problem
Yes, cRIO devices absolutely do work on LV2015. That's why I think there is an installation issue.
(blog)
Message 11 of 14
(1,811 Views)
Accepted by Ali.AZZUBI
I would agree with Sam here.  I work almost exclusively in 2015 and have used a cRIO from every family at one point or another so I can confirm that there is no compatibility problem.
I would make sure that ADE support is installed for your RIO drivers.  I am suspecting that this is a problem with the RIO driver because it is not letting you add any c-series modules (even if it cannot find actual modules you should be able to add a generic module).
Message 12 of 14
(1,794 Views)
Ok, problem solved.
You were right, I had a software installation problem.
My 2015 cRIO driver was an update from installed 2014. When I installed a fresh copy of 2015 driver, system worked as expected.
I had a similar issue with myRIO before, i.e. when I update drivers to 2015 from 2014, system presents discovery issues. Similarly, fresh copy of drivers solved the issue.
I can't state a conclusion here. Nevertheless I thank you all for sharing your thoughts.
Message 13 of 14
(1,777 Views)
thanks, I had the same problem and this helped me solve it with one extra step:
1. I installed the CRIO device drivers on the PC again.
2. I removed the already installed software from the CRIO and installed it again in NI MAX.
3. Last important step was: I removed the Chassis from my LabVIEW project and added the chassis again. Then it would automatically discover my modules.
Cheers,
Robin
Message 14 of 14
(1,611 Views)
