cRIO 9075 Hybrid mode code example
I’m looking for a LabView code for cRIO 9075 with 9514 module and 9239 module in Hybrid mode.
NI 9514 used for control servo motor in scan mode, NI 9239 (only one channel input) used for sensor signal voltage input in FPGA mode.
I have made some codes for FPGA and motor control, they are running in their own mode are no problem. I tried to put two together in Hybrid mode follow the guide provided by NI white paper got so confused. Just couldn’t get right.
I’m a first timer to cRIO platform, please help me. Thank you so much in advance!
Gangyong
(3,300 Views)
Hi Gangyong,
Here is a forum post that goes over the situation that you are experiencing that has some great steps to try. I think reading that will help you get started.
Paolo F.
(3,252 Views)
