cRIO LabVIEW StartupApp manually start
  • cRIO LabVIEW Startup Application
Does anybody know how it's possible to manually start / kill / restart a cRIO "startup.rtexe" application with Linux commands?
I think the auto startup feature (I used shared network variables) has a problem in my application when NTP corrects the time from 01.01.1904 (myRIO no battery for the onboard clock) to the current time. In development mode with correct NTP time everything works fine.
Thanks for any advices.
Greetings David
 #development #cRIO #LabVIEW #linux
(2,395 Views)
Accepted by DavidLabview
Short answer, yes:
/etc/init.d/nilvrt stop && /etc/init.d/nilvrt start
For more info see e.g. here or here.
(2,365 Views)
Hi cordm,
Thanks a lot for this information. You helped me more and better than some discussion's I had with the NI support if this is would be possible and they wasn't sure.
I tested it with my smartphone via VPN and mobile ssh and it worked, cause I'm on vacation:-).
Thanks & Greetings David
(2,333 Views)
