cRIO (Linux RT) doesn't shutdown
Hey,
When I try to shutdown my RT Linux using "shutdown now" command in terminal. shutdown process is stopped (see picture) and cRIO is not shut down.
Any idea to fix that ?
Thank you
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
(3,417 Views)
What are you trying to do exactly?
Turning off the hardware? If yes, I don't know how to do that.
It seems like the "shutdown now" cmd only stops the software.
I SSH into my Linux RT Target, and sent "shutdown now", the target replies "going to maintenance mode"
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,400 Views)
Hi Titou,
I just want to stop OS without turning off the power.
I 'd like to have running services stopper as clean as possible.
Having a service that not stop at shutdown could be a clue that something is going wrong on the OS. Not a good think when you want your app to run 24/7 🙄
Olivier Jourdan
(3,393 Views)
I don't fully understand what you're trying to do, have you seen this : https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kHDxSAM&l=en-GB
Epictetus
Antoine Chalons
(3,385 Views)
