cRIO Run Multiple Applications?
Is it possible to run muliple applications on a cRIO target?  Would they all need to be part of the same LabVIEW project?  Can I set more than one as a start-up VI or need to create a VI that would start up the individule applications?  They are Ethernet bases and don't use or share any I/O.  I looked around but don't see much information on this topic.  Thanks!
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
(3,559 Views)
Accepted by CAS_MattF
Good Afternoon Matt,
      It is possible to run multiple applications on a cRIO target as long as they're in the same project and don't exceed the memory capacity of the target. You can only mark one VI as the start-up VI but, as you mentioned, you could have this VI call your other applications. You may find the following documentation helpful:
Programatically Launch an Executable or VI on a Real-Time Controller
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIE4CAO&l=en-US
Using VI Server to Run LabVIEW Real-Time VI's Stored on an RT Series Hard Drive
http://zone.ni.com/devzone/cda/epd/p/id/4364
Getting Started with the LabVIEW Real-Time Module
https://www.ni.com/docs/en-US/bundle/371375f/resource/371375f.pdf
Hope this helps!
--Ryan S.
(3,529 Views)
Thanks!  I will be trying this out in the next few weeks.  I will report back it I have any issues.
Matt
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
(3,517 Views)
