06-01-2015 03:55 PM
I'm on a 9067 which is a linux chassis.
You don't happen to know where the config file sits on the 9067, do you?
06-08-2015 10:06 AM
I was having the same issue; Caused by a mismatch between the actual system and my project. Actually, I intentionally left the Chassis and EtherCAT device out of my project because my application is designed to be flexible and programmatically detect the hardware modules and connect to I/O variables.
When I try to run from the dev environment, it ALWAYS pops-up the Conflict Resolution dialog, stating:
At least one deployed item is no longer in the project.
You can use the "Project & System Comparison" dialog box to view the missing items. Cancel this operation and right-click the target item in the Project Explorer window and select Utilities >> "Compare Project & System" from the shortcut menu to launch the "Project & System Comparison" dialog box.
The default 'conflict resolution' that is selected on the dropdown box is 'Undeploy all missing items'. If I leave it like this and click 'Apply', deployment will fail as you describe. If I switch the option to 'Do not undeploy the missing items', then deployment succeeds without error!
If you're attempting to do a similar thing - expecting project/system mismatch - I hope this solution works for you too. I don't expect this solution to work (nor do I recommend it) if you require your project to match your system deployment.
04-17-2024 09:42 AM
The method of removing the files works, here's the full path that was missing from the last post.
\var\local\natinst\deployfwk\config
I deleted all the xml files in the location. They were recreated when a added the ECAT master and scanned the network in my labview project. I have my crio mapped in windows to get to these files.
Hope this helps someone.
06-11-2025 11:50 PM
Hello, Regis,
now i tried your guide and for me it is fully functional.
Thanks.
