calculating phase from corresponding dc values
i am using kithley2010 for measuring dc values from agilent 82357A USBto GPIB converter. DC values varies from 0v
 to 15v ....15v corresponds to 180 degree , 7.5v corresponds to 90 degree and 00v corresponds 0degree. i dont know how to make VI for this logic...waiting for ur reply
(3,052 Views)
You have actually solved your problem already :smileyvery-happy: But take a look here 180(deg)=15V What do you have to do in this equation so the right side shows 1V? Then you find out you have a factor you can multiply all your voltage measurement to convert them to degree
good luck
Message Edited by Coq rouge on 05-30-2009 10:43 AM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,042 Views)
