calculating the volume
I would like to calculate volume of a liquid infused/withdrawn from a syringe pump. I will know the rate and time, but here's my volume formula:
Volume = RATE * (TIME(1) - TIME(0)) + PREVIOUS VOLUME
So I want to take the rate and multiply it by the difference of the original and previous times and then add the previous volume.
Message 1 of 16
(5,116 Views)
You can either use a state machine and Shift Registers for "memory" to keep track of the previous result, or
You can use feedback nodes to send the result data back to the beginning of the formula.
CLD | CTD
LabVIEW 2011 SP1 | TestStand 4.5
Message 2 of 16
(5,112 Views)
Use shift registers to hold your previous time and volume.
Message 3 of 16
(5,110 Views)
Would ya'll be kind enought to maybe show me an example?
Thank You,
Mike
Message 4 of 16
(5,102 Views)
Thank You,
Mike
Maybe you should start thinking about taking the free online tutorials hmmmm?
http://www.ni.com/white-paper/5241/en
Message 5 of 16
(5,097 Views)
Thank You,
Mike
You mean my link to the video wasn't good enough for you?
Here's one for you to play with.
Message 6 of 16
(5,091 Views)
Oh sorry! never saw the link.
Yea i will go ahead and mess around with it some. if i have any questions than i will post.
Thanks!
Message 7 of 16
(5,064 Views)
ahh i'm still having some trouble. I looked at the videos and read the tutorial. My program looks pretty complex already. attached is my code.
I want to calculate the volume by using the rate multiplied by the time (ex: T(1)-T(2)) + the previous volume.
I want to use the seconds in the timestamp that I already have in my program
Message 8 of 16
(5,046 Views)
Ok, so where are you stuck?  What is it that you don't know how to do?
Message 9 of 16
(5,037 Views)
Message 10 of 16
(5,032 Views)
