calculating the volume
I recently started receiving this error that I used to never get:
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488:  Command requires GPIB Controller to be Controller-In-Charge.
What is that?
Message 11 of 16
(929 Views)
I cannt read your code, i have previous version (2009), here is a solution:
But I know that in practice it is better measurement the count of pump strokes, and multiply by the stroke volume.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 12 of 16
(919 Views)
thank you Luis!
Does anyone know what the Error that I am getting is? I posted it a few comments back
Message 13 of 16
(909 Views)
Where is it occurring?  Use highlight execution and probes.
It sounds like you have a bad filename.
Message 14 of 16
(906 Views)
Yea thats what I think it is. It's occuring right at open_create_replace file name.vi
Message 15 of 16
(904 Views)
And if you put a probe on the wire for the file name .... ?
Message 16 of 16
(895 Views)
