call library function node with a pointer to a struct with contains fixed sized arrays
i want to call a function in a dll. one of the parameters is a pointer to a structure where some of the fields are arrays. see below.
i've seen several suggestions on how to do this. i was wondering which is the best way to handle this particular case.
i need my vi to support version 8 and later. 32 and 64 bit.
thanks.
#define MAXCHANNEL                      0x6        // Maximum number of channels on a card
typedef struct _D2S_OUTPUT_STATUS
    BOOLEAN bPowerActive;                      /* True - Power Active; FALSE - Power Inactive */
    BOOLEAN bS1Active[MAXCHANNEL];   /* True - Active; FALSE - inactive */
    BOOLEAN bS3Active[MAXCHANNEL];
    BOOLEAN bS2Active[MAXCHANNEL];
    BOOLEAN bS4Active[MAXCHANNEL];
}D2S_OUTPUT_STATUS, * PD2S_OUTPUT_STATUS;
S16 _DECL Get_D2rsOutputsStatus(S16 s16DevNum, PD2S_OUTPUT_STATUS pOutputsStatus);
Message 1 of 8
(3,912 Views)
What are the methods you are considering?
There's only one good way to do this that I know of: create a LabVIEW cluster that matches the struct, replacing the fixed-size arrays with clusters containing the correct number of elements.  Pass this cluster to a call library function node with the type set to "Adapt to Type."  Clusters are passed by reference (pointer).  Your cluster should use a numeric of an appropriate integer size instead of BOOLEAN (if I remember correctly that's a U32, but you should confirm this) - LabVIEW's boolean will not necessarily have the same numeric representation.
Message 2 of 8
(3,907 Views)
My preferred approach: Ask the manufacturer of the device for a LabVIEW driver.   Do they have one? Do they have plans for a LabVIEW driver?
Next best approach: You create a set of VIs that run the according call library nodes.
Message 3 of 8
(3,902 Views)
i have seen the cluster approach as well as creating a wrapper dll.
Message 4 of 8
(3,900 Views)
ah, that we be us.
i am creating wrapper vi's to the function calls into our library and sample apps.
Message 5 of 8
(3,899 Views)
I would prefer creating the wrapper VIs, too.
Writing a wrapper.DLL would involve that you have to maintain the DLL for 32bit and 64bit.
Message 6 of 8
(3,895 Views)
we currently have wrapper dlls for some other products and we maintain 32/64 bit dlls.
i had to create a wrapper anyway for this product. so i might add this. i'll see how i feel.Smiley Happy
Message 7 of 8
(3,891 Views)
If you already maintain wrapper DLLs then I would add this function to the wrapper and give it a "LabVIEW friendly" interface.
Message 8 of 8
(3,885 Views)
