calling a VI in another VI
What I want to do is have 4 buttons on the front panel of one program. This program will be the one mailny in use. But now I need help with:
If I hit one button, then that code should run. If I hit the 2nd button, another VI should run. If I hit the 3rd button, the 3rd program should run and if I hit the 4th butotn the 4th programs hould run.
What I want ot know is how to lik these buttons to 4 different programs and be able to call all from one main program?
(2,422 Views)
The easiest way is to use an event structure and a value change event for each boolean. Put the subVI in each event.
This is very basic. You should probably look at the learning LabVIEW resources available at https://learn.ni.com/learn/article/labview-tutorial.
(2,419 Views)
