measuring temperature Via Thermocouple and USB-6009?
I am trying to perform temperature measurements using a k type thermocouple and the USB-6009 DAQ. I tried to use the Cont Acq Thermocouple Sample.vi from LabVIEW's example list, but unfortunately I don't know how to fit my DAQ and thermocouple in the vi code. I don't know how to create a thermocouple temperature measurement channel or how to get all the channels in the task, etc.
Any help is appreciated.
Thanks.
(4,933 Views)
You should be able to use DaqMx to configure a task that will do this.  It should be pretty straight forward.
(4,925 Views)
I used daqmx to configure. I have my thermocouple attached to the right port, but the readings seem a bit off. the temperature goes from 0 to 100 C in like 2 seconds. Do you think my thermocouple is broken? Also, I dont know what to put for "error in".
I'm attaching a picture of my front pannel to show you the graph ...
Thanks again
(4,905 Views)
It sounds like you have a noisy input. Remember thermocouple values are in the 10s of milli volt range.
(4,900 Views)
bilbeigg,
It should be noted that the USB-6009 is not well suited for thermocouple measurements.  It has 14 bits of precision with a minimum input range of +/-1V, which means it can only detect a voltage change as small as about 122 microvolts.  This is much too large a change to get a good temperature reading with most types of thermocouples.  Here is a discussion thread on the same topic (Note that the USB-6008 and 6009 are very similar):
Here is a knowledgebase that explains what you are seeing:
Chris M
Message Edited by CMal on 03-12-2008 12:17 PM
(4,887 Views)
