can I insert my own buttons into a vi
Is it possible to substitue some of the standard buttons in a VI with my own and make them functional?
(2,836 Views)
Yes you can customize a button by right clicking the button go to advanced->customize and you can add a image onto your button or customize it as needed
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(2,835 Views)
this may help :
http://forums.ni.com/ni/board/message?board.id=170&message.id=429818&query.id=782581#M429818
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(2,832 Views)
Thank you for the help.... this was pretty simple.  However, one last question;  I saved the edited button as a CTL file in my root directory but I can't seem to find it again within the Labview Controls dialog.  I assumed I would be able to put it under the Users Control area but I can't figure out where would I put this new CTL file in the folder structure so I can find it under the User CTL choice.  Any suggestions?
(2,798 Views)
Accepted by topic author irfocus
Go to Tools>Advanced>Edit Palette Set. There you can rightclick the Controlspallete and select "Insert Custom Control" (or something like that)
Christian
(2,793 Views)
