12-16-2009 08:22 AM
Solved! Go to Solution.
12-16-2009 08:27 AM
12-16-2009 08:34 AM
this may help :
http://forums.ni.com/ni/board/message?board.id=170&message.id=429818&query.id=782581#M429818
12-16-2009 11:23 AM
Thank you for the help.... this was pretty simple. However, one last question; I saved the edited button as a CTL file in my root directory but I can't seem to find it again within the Labview Controls dialog. I assumed I would be able to put it under the Users Control area but I can't figure out where would I put this new CTL file in the folder structure so I can find it under the User CTL choice. Any suggestions?
12-16-2009 11:34 AM
Go to Tools>Advanced>Edit Palette Set. There you can rightclick the Controlspallete and select "Insert Custom Control" (or something like that)
Christian
