can NI 9263 and NI 9219 used to generate and acquirinfg ac signal
nripen kalita
(2,993 Views)
Yes.
You know you can put a lot more text in the message than just in the header line?
(2,979 Views)
Sir can you please mention the pin number i have to used.
thanks.
(2,976 Views)
pin numbers depend on the channel you want to use.
Read the manual - or configure a task in MAX, it will show you which pins to use...
(2,969 Views)
sir can you please mentioned the step how to write the data to a file.
your's faithfully
Nripen
(2,940 Views)
Hi Nripen,
you still write very unspecific questions, so you will receive very unspecific answers...
Open the file functions palette. You will find a lot of functions to save data to files!
(2,936 Views)
