can i execute the testing of adevice by using jtag on labview
asking for a solution does'nt mean that to do the entire project. communities are mean't for the sharing of ideas and helping fellow men. keep your ethics safe and do your work. it suits better to you.
Message 11 of 16
(1,023 Views)
ok. you please give the specific application  for which you are using the  jtag alongwith labview.
Message 12 of 16
(1,011 Views)
nyc wrote
So, it is okay to ask for someone to do your school project for you ????
At my university that is grounds for explusion since it an ethics violation.
asking for a solution does'nt mean that to do the entire project. communities are mean't for the sharing of ideas and helping fellow men. if you can't , keep your ethics safe and do your work. it suits better to you.
Message 13 of 16
(1,006 Views)
Sure sounds like you are asking us to do a big chunk of your project.  But let us even forget about ethics and school projects, or whatever.  *YOU* are the one who knows what these boards do, so *YOU* are the one that will have to decide how to test them.  Since we did not design the board to be tested, we have absolutely no idea what you might even need to get started.
Do some research.  Look around for examples.  Ask your professor for a little guidance.  It doesn't seem like he's given you adequate information on the subject matter.  Develop a test plan, THEN come to us for help on translating your test plan into LabVIEW code.
Bill
CLD
(Mid-Level minion.)
Message 14 of 16
(977 Views)
thanks. i will go through my work. but  my intention is not that to ask to do my project or even not about the testing of boards. i had gone through some manuals and i found using jtag in my application can help me better. and that's what i had asked you people.
the next time i will be specific to you .
Message 15 of 16
(960 Views)
Write up a test plan that describes how you want to test these boards.  Include the specs of the UUT as well as test-for sepcs.  When you've done that, then you are ready to ask questions about how to implement it in LabVIEW...
Bill
CLD
(Mid-Level minion.)
Message 16 of 16
(940 Views)
