can not download FRCLabVIEWUpdate2.0.zip
The download asks you to sign in. I sign in and then try and download again and am redirected back to the signin page. I have verified that I am signed in by going to personal preferences.
(2,841 Views)
Hi 1070,
do you mean on this link? I see no problem with downloading it.
Mike
(2,836 Views)
Accepted by 1070
Hi 1070,
Once you are logged in, do you see "Hello <YourName>" in the top right corner below the Search field?  If you are able to log in but can't download the update, a firewall or anti-virus software may be blocking access to the National Instruments FTP site.  You can try to download the update directly from ftp://ftp.ni.com/support/softlib/first/frc/FileAttachments/.  If that still doesn't work, you will probably need to adjust the anti-virus software to allow FTP sites or try using a different computer.
For any future questions you have about National Instruments and FIRST, you'll likely get more responses by using the FIRST Community discussion forums at ni.com/first
Hope that helps!
Jennifer R.
Applications Engineer
(2,811 Views)
Thanks everyone for the help. It turns out the problem was with Firefox, IE downloaded the file with no problem.
(2,797 Views)
