can not download FRCLabVIEWUpdate2.0.zip
The download asks you to sign in. I sign in and then try and download again and am redirected back to the signin page. I have verified that I am signed in by going to personal preferences.
(2,836 Views)
Hi 1070,
do you mean on this link? I see no problem with downloading it.
Mike
(2,831 Views)
Accepted by topic author 1070
Hi 1070,
Once you are logged in, do you see "Hello <YourName>" in the top right corner below the Search field?  If you are able to log in but can't download the update, a firewall or anti-virus software may be blocking access to the National Instruments FTP site.  You can try to download the update directly from ftp://ftp.ni.com/support/softlib/first/frc/FileAttachments/.  If that still doesn't work, you will probably need to adjust the anti-virus software to allow FTP sites or try using a different computer.
For any future questions you have about National Instruments and FIRST, you'll likely get more responses by using the FIRST Community discussion forums at ni.com/first
Hope that helps!
Jennifer R.
(2,806 Views)
Thanks everyone for the help. It turns out the problem was with Firefox, IE downloaded the file with no problem.
(2,792 Views)
