can not enable ssh on Phar Lap ETS
I have a dual boot controller PXIe-8840 with Phar Lap ETS 13.1 installed on it.
I can connect to the controller in MAX and install NI real time, but i can not enable SSH connection.
Not in MAX, not in Web Configuration Panel there is no "Startup settings" where ssh can be enabled.
Does this RTOS support SSH?
(4,049 Views)
Accepted by ilyashatan
To my knowledge: NO.
Regards, Jens
Kudos are welcome...
(4,025 Views)
Have you tried just doing it anyway even though the option isn't there? I am looking into an official answer on this.
CH
Applications Engineering
http://www.ni.com/en-us/support.html
(3,978 Views)
I also think the answer is no. Only the NI Realtime for Linux based controllers support SSH. It may be possible to install a command line SSH server for Windows on Pharlap, but that is generally a tricky thing, as only executables created with specific Visual Studio versions (VS 6.0, VS 2003, VS 2008 and VS 2010) will be possible to run on the Pharlap system.
Rolf Kalbermatter  My Blog
(3,970 Views)
I tried to connect to ssh on port 22, but connection is refused.
(3,947 Views)
