can not find hp4912
Hi, All,
I am tryint to program with hp4912A LF IMPEDANCE ANALYZER.
I used KUSB-488A to connect the instrument to my computer. I downloaded and installed the driver for KUSB-488A and the computer did detect this device. So I opened the labview 2010 (I am also attaching the software I installed) and scan for instrument. And it showed that " no connected instrument detected".
What else should I do?
Joyce
Message 1 of 11
(4,163 Views)
Replace the keithley with NI hardware?
Did you enable tulip support in MAX?
Message 2 of 11
(4,158 Views)
what is tulip support?
Message 3 of 11
(4,155 Views)
Well,
First - according to your screen capture- you failed to install the device drivers.  NI-VISA and NI-488.   without at least the NI488 driver you will not be able to use NI products  to talk to the device.
Simple fix- pop in the Device Drivers dvd and install them.  Or download from here
Message 4 of 11
(4,154 Views)
Dennis- Tulip support wont be avalable without VISA
Message 5 of 11
(4,151 Views)
Do I then still need KUSB-488A driver from Keithley?
Joyce
Message 6 of 11
(4,147 Views)
Joyce
Probably, I would not uninstall them, Hard to say without experimenting.  You definatly need to install NI Device Drivers.  You may need to do other things but, VISA support for LabVIEW seems pretty important for now.Smiley Wink
Message 7 of 11
(4,142 Views)
Thanks for your reply. I will try.
Thanks.
Message 8 of 11
(4,139 Views)
Accepted by Joycezh
NI-488 will not work with the keithley.
Message 9 of 11
(4,134 Views)
So I installed all the drivers from NI.
When I plugged the KUSB-488A, the windowns can not identify the device. From MAX, the device is not detected either. I tried to install KUSB-488A driver, it says that it conflicts with NI 488.2. Should I delet NI 488.2 and install KUSB-488A driver?
many thanks,
Joyce
Message 10 of 11
(4,130 Views)
