can not get teststand SequenceContext
Hi Community,
from the bottom picture,i can not read 'Local.a' in the sequence,but i can get the RunState,it seems the probe 1 is 0.
any suggestions welcome
thanks!
(2,048 Views)
Use SequenceFileViewManager
(2,001 Views)
a=1(probe 6),but probe 1 is 0(with no error),is there something i missed?
my goal is to get the SequenceContext by LabVIEW,then i can get data in the sequence.
until now i use stupid ways to get data in the sequence.
(1,975 Views)
Accepted by Yuanxj
Hi Yuan,
@Yuanxj wrote:
my goal is to get the SequenceContext by LabVIEW, then i can get data in the sequence.
Calling a VI from TestStand and giving ThisContext as a parameter is the preferred/recommended way, so why do you think this would be a "stupid way"?
(1,941 Views)
Accepted by Yuanxj
XiaoJian,
You are using Operator Interface.  It's purpose is to run sequences.
Leave the data manipulation to sequences and their VIs.
To most users, TestStand is not as flexible as LabVIEW.
George Zou
(1,928 Views)
Accepted by Yuanxj
And if you want to send simple data to your operator interface, then use User Messages.
(1,909 Views)
thanks all!
(1,875 Views)
