can't assign xcontrol as terminal
Historically, we can easily assign any instance of xcontrol to a terminal pin but LV2011 changed all that.  I have to deactivate the xcontrol just to assign it to terminal then reactivate it.  This is very inconvenient because I have tons of xcontrol instances that I need to work with.  Is there a setting somewhere in LV2011 that wil allow me to assign xcontrol to a terminal without this hassle?
Message 1 of 13
(4,052 Views)
What is the meaning of "deactivate"? (this term is typically used with licensing).
Message 2 of 13
(4,044 Views)
correct activate/deactivate to: lock/unlock for editing
Message 3 of 13
(4,038 Views)
I am not aware of this behavior being changed between LabVIEW  2010 and LabVIEW  2011, I am putting together a simple example to see if the behavior changes between the two versions.
Message 4 of 13
(3,999 Views)
Jeff,
Could you please check into LV2008 (v8.6) too?  I just swapped from version 2008 (8.6) to 2011.  In 8.6, we never have to unlock the xcontrol for editing before assigning it to a terminal while 2011 requires it.  This is very inconvenient and not user friendly when you have tons of xcontrol instances to work with.
Message 5 of 13
(3,988 Views)
I was able to recreate the behavior you described. In 2010 after dropping an xcontrol on the front panel I can connect it to a terminal, but in 2011 I have to unlock the xcontrol before I can connect it to a terminal. I am checking to see why this was changed and if there is an option to change the behavior back.
Regards
Message 6 of 13
(3,970 Views)
This issue has been escalated to R&D and CAR 334784 has been logged regarding this. There is no option to change this behavior.
Thank you for bringing this to our attention,
Message 7 of 13
(3,948 Views)
Hi Jeff,
Five years laer and I'm running into the same problem.... is there a solution?
Rgds,
Seán
Message 8 of 13
(3,802 Views)
Hey Sean,
At this time, the only way to link an xcontrol to the VI terminal is still to unlock the xcontrol and link it while unlocked. We have this requested change on file under the CAR number further up-thread, but no change related to this behavior has been implemented.
Cason
NI Applications Engineer
Cassandra Longley
Senior Technical Support Engineer - FlexRIO, High Speed Serial and VRTS
Message 9 of 13
(3,787 Views)
Gee, I can't connect an xcontrol to a VI terminal regardless of whether it is locked or not (LV 2016).
Message 10 of 13
(3,781 Views)
