Report Generation slow when network cable pluged in
I have a very strange problem.
I am using LabVIEW 2014 and Report Generation toolkit 2014.  When I have the ethernet cable plugged in it takes a very long time to generate my report in word.  When the Ethernet cable is unplugged I don't have a problem.
Any ideas?
Dan Shangraw, P.E.
(5,142 Views)
Sounds creepy, I think you can check your CPU utilization when you plugged cable.
It might be your computer doing something and it slow your VI running.
Patrick
Certified LabVIEW Developer
(5,136 Views)
Accepted by topic author ASTDan
Maybe there's a networked printer configured on your system? Some of the Report Gen VIs deal with the system printer(s), and if there's a problem connecting to one of them, I could see that causing the code to slow down.
Most of the VIs in the toolkit aren't password-protected, so you could use execution highlighting to see which specific subVI gets bogged down.
(5,123 Views)
The default printer was set to Micorsoft One Note.  I changed the default printer to PDF and the slowness went away.
Thanks so much for the sugestion
Dan Shangraw, P.E.
(5,033 Views)
I do not know where the exact cause is. For me, it is probably the incompatibility of LabView 2013 with Office 2013. But it seems I was able to fix the problem by manipulating the VI "Dispose Report". Please note the pictures: First is original, second is manipulated. I have deleted closing the "InlineShapes". The VI can be found here: ... \ National Instruments \ LabVIEW 2013 \ vi.lib \ Utility \ NIReport.llb \ Word \ Dispose Report.vi.
(4,774 Views)
This is potentially creating memory leaks if there ever was anything populating that data element in the object data cluster. So handle with care!!
Rolf Kalbermatter  My Blog
(4,757 Views)
