pci 6013_window 7 compatability
Ive tryed searching to see if my PCI 6013 is compatible with  my version of windows
i have a windows 7 w/sp1
 i plan on running labveiw 12
ive have a pci 6013 and want to be sure its compatible with my os.
will the latest measurement automation support this?
I also have a mating cb 68lp
thanks in advance
(3,727 Views)
Accepted by Hooovahh
If you dig around NI's site, they normally have compatibility tables comparing OS, LabVIEW and driver versions. These two links show DAQmx version compaibility with different Windows versions, and also compatibility between DAQmx versions and LabVIEW versions.
https://www.ni.com/en/support/documentation/compatibility/21/ni-hardware-and-operating-system-compat...
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
You should be covered up to DAQmx 15.5.1 on Windows 7 SP1 and LabVIEW 2012 (note DAQmx 16 doesn't support LabVIEW 2012). If you look on the download page for DAQmx 15.5.1, it shows the PCI-6013 as supported: https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288253
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(3,681 Views)
Thank you for links
(3,650 Views)
