can't check FGPA reference with "Not a Number/Path/Refnum?"
As a quick test before I tracked down an actual R Series card, I ran the code with the "Execute on Development with Simulated I/O" setting to simulate your hardware and I got the same behavior. I tried running with execution on the development machine with my cRIO, but ran in to errors regarding how execution on cRIO works (it's different than R Series, so to run these tests I have to actually execute on the RIO). The real test here will be how the test behaves with a real R Series set to execute on the FPGA.
Tim W.
Applications Engineering
http://www.ni.com/support
Message 11 of 16
(1,222 Views)
So I finally got a PCI-7831R in my machine to test this behavior. When the host VI is run and execution is set to go on the FPGA both dynamic and non-dynamic modes behave as expected and give false values for the boolean. However, when I switched execution to the development computer with simulated I/O, I got a false in dynamic mode and a true in non-dynamic mode. I think this behavior has something to do with the execution settings and may be a bug. We would both expect the reference to work the same way in simulated execution and actual FPGA execution. I'm going to file this with R&D and see what they have to say about it.
Tim W.
Message 12 of 16
(1,208 Views)
Accepted by nathand
This issue has been filed with R&D. The reference number for the corrective action request is 339079.
Tim W.
Message 13 of 16
(1,205 Views)
Thanks for this. I'm out of the office for a few days but will double-check the behavior in LabVIEW 2009 when I get back, since that's what the lab systems are using. A coworker reported that the application I built in 2009 wasn't working properly and when I ran it on my machine (in simulation) I saw this behavior and assumed it was the problem on the real system with an FPGA. Adding a boolean to indicate if the FPGA was available solved the problem. Now you're telling me that in 2011 the behavior is different in simulation versus with a real card; I'll have to check if that's a change since 2009.
Message 14 of 16
(1,200 Views)
Forgive me, as I havent read this whole thread. But would a possible work around be to typecast the reference to an int and check if its greater than 0?
Message 15 of 16
(1,197 Views)
Haha last line of your post says my suggestion above. Doh!
Message 16 of 16
(1,194 Views)
