can't connect to the server using HTTP method (Fail GET : 404)
i just made a programs of monitoring feature for waterhammer phenomenon using Labview and IoT with HTTP method (web server) and my problem is my labview can't get data from my esp32, from serial monitor in arduino ide it tells me about fail GET : 404, how do i fix this?
Message 1 of 8
(1,121 Views)
Start with showing what you are doing. Attach your VI and the communication protocol.
Message 2 of 8
(1,097 Views)
HTTP error 404 means resource not found, which means you reached an HTTP server but there is nothing at that URL.
Message 3 of 8
(1,088 Views)
Just to expand a little bit, this error comes from the server.
Bill
CLD
(Mid-Level minion.)
Message 4 of 8
(1,064 Views)
have
any ideas to fix this?
Message 5 of 8
(1,056 Views)
@Angh_9989 wrote:
have
Sure.  Give it the right URL.  If you're sure it's the right URL then fix the server.  I don't mean to be mean, but are you sure you are the right person to be doing this?
Bill
CLD
(Mid-Level minion.)
Message 7 of 8
(1,038 Views)
So you are trying to POST data from Arduino to a LabVIEW web service? Using the word get is confusing, because in an HTTP context it would imply that LabVIEW initiates the connection to a server.
Here are the available endpoints of the server:
Do you have a typo on the arduino side perhaps? selenoid <> solenoid?
Message 8 of 8
(1,012 Views)
