how get cluster element value change event
hi,
       i have cluster .i chage any one of the value in cluter element .may i know about which element is changed using common value change event structure.
Message 1 of 33
(9,988 Views)
Property node >> Control Label
Edit: Don't choose <All Elements> for the event source, choose which cluster element you want.
Message 2 of 33
(9,984 Views)
You can easily create a seperate event for each cluster element.
Message 3 of 33
(9,977 Views)
And if you want to get the new value you can cast the control reference to the proper type using a "to More Specific" node as you will see in this old nugget.
Ben
Message 4 of 33
(9,968 Views)
What I sometimes do is compare old and new from the event data node using "not equal", convert the resulting boolean cluster to a boolean array (cluster to array) and search for the single true element (search array). The resulting index (typically wired to a case structure) will give you the element position in cluster order.
Message 5 of 33
(9,957 Views)
I used that same approach on my first CLA exam!
Ben
Message 6 of 33
(9,953 Views)
In each case, I unbundle the relevant element(s) and process accordingly.
Message 7 of 33
(9,947 Views)
When I have apps that need a lot of controls, I will sometimes nest event structures.  A case in the outer structure to capture all value changes for a cluster, and an inner one to separate value changes for individual cluster elements:
Message 8 of 33
(9,890 Views)
Why do you even need the outer event structure?
I would strongly advise agains stacking event structures in general.
Message 9 of 33
(9,871 Views)
i know this way. why i asking this mean i have lot of even structure so need to reduce the number of event structure in my program.
Message 10 of 33
(9,833 Views)
