how get cluster element value change event
How do you create an event for each cluster element? I have an array of clusters.  I would like to know if a button is clicked in a particular cluster.  How do I get to that button?
Message 21 of 33
(2,755 Views)
You can not configure an event for a particular element of an array.
You could configure the event for a value change of the array, then do a compare of the old and new to decide which element in the array changed and then determine which element in the cluster changed.
Now if you used a cluster of clusters on the FP instead of an array...
You could configure an event for an element in all of the clusters.
Pick your poison, use and array and do more coding or switch to a cluster of clusters and let LV tell you which one changed.
Ben
Message 22 of 33
(2,754 Views)
AryOfClusters.JPGThanks.  That's what I figured I would have to do.  I don't know that I can create a cluster of clusters because the number of lines is dynamic.
Message 23 of 33
(2,750 Views)
If you can specify a max number of elements you can create a cluster on the GUI that is large enough and then hide the ones that are not valid.
Just trying to make your job easier... if there is a chance!
Ben
Message 24 of 33
(2,744 Views)
Thanks!  I like that idea.  I will investigate.
Message 25 of 33
(2,741 Views)
A couple of things.  First a solution to the question about cluster value changes. Here is a post I made where there are an array of clusters and you want to know what element in what cluster changed value.  In this case we were looking to find which button was pressed, but the point is that you can use the New and Old value, performing a Not Equal, and detect what element in the cluster had the value change.
Secondly having an event structure inside an event structure is a bad coding practice.  Even NI R&D had put serious thought into limiting each block diagram to only having one event structure since so many new developers were shooting themselves in the foot and abusing it.  There are also VI Analyzer tests to help find VIs that have multiple event structures, as well as a few other event based pitfalls.
Message 26 of 33
(2,715 Views)
To elaborate on the emphasized point above, if the clusters are the same - and this would definitely apply here - an EQUALS comparison will yield a cluster of Booleans with the same structure as the clusters being compared.  Any Boolean that is FALSE tells you the corresponding value has changed.
Bill
CLD
(Mid-Level minion.)
Message 27 of 33
(2,705 Views)
@altenbach wrote:
What I sometimes do is compare old and new from the event data node using "not equal", convert the resulting boolean cluster to a boolean array (cluster to array) and search for the single true element (search array). The resulting index (typically wired to a case structure) will give you the element position in cluster order.
I have tried performing the same comparison myself but I do not know what you mean by "convert the resulting boolean cluster to a boolean array" Do you have a boolean cluster that you are checking for a change?
How would you go about finding the changed element if you are comparing against a cluster that has multiple data types e.g, string, string, boolean? Inside a 1d array.
Message 28 of 33
(2,484 Views)
Sorry for commenting an old post, but since no answer was marked as solution and the question might come up often, the following picture might help to handle changed cluster elements. (Array of cluster is a different question...)
also see https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000owfZCAQ&l=de-DE
Proud developer at Hampel Software Engineering where we turn '404 not found' into '200 OK'. Join us on Discord
Message 29 of 33
(1,394 Views)
You can register for Cluster element value change through their references.
Qestit Systems
Certified-LabVIEW-Developer
Message 30 of 33
(1,383 Views)
