how get cluster element value change event
The event processing is the way to do it. Comparing huge clusters of controls is going to take a lot longer-and the memory manager has to make copies of all that data to compare it, and create a new same-sized cluster [struct array] of booleans.
I'm sure if I benchmarked these two methods it would not be close.
Message 31 of 33
(328 Views)
Make a Reference to a cluster element and register that Value Change event. It'll fire on all changes if in an array though.
Qestit Systems
Certified-LabVIEW-Developer
Message 32 of 33
(305 Views)
Just in case somebody else also needs this for clusters in clusters here is a version that unpacks those and retrieves the changed element.
Message 33 of 33
(56 Views)
