can't find DAQ assistant in LabView
Hi! I installed the NI-DAQmax driver 9.3.5 after installing LabView 8.5 Student edition and I am not able to find the DAQ Assistant in the function palette. Could you please let me know what else could I do?
Thanks!
Message 1 of 16
(21,070 Views)
Install an earlier version of DAQmx since 9.3.5 is not compatible with LabVIEW 8.5. The latest version that is version 9.3.
Message 2 of 16
(21,067 Views)
I just did what you suggested and I still have the same problem. Should I uninstall LabView and download everything again? I have tried many things and nothing seems to work. This will be my last thing to try. Thanks!
Message 3 of 16
(21,050 Views)
Removing LabVIEW would be the last thing I would try. Did you first do an uninstall of the newer version? What does MAX show as being installed?
Message 4 of 16
(21,045 Views)
Yes, I removed the Later version (9.3.5) before installing the earlier one. The earlier one that I just installed appears as part of the National Instruments files but when I launch LabView and try to create a new block diagram It does not appear in the Function Palette. Similarly, when I open an old LabView field that has been previously defined in another computer with another LabView user I cannot run the program as it gives me the error that DAQmax (which is the input function) is not installed.
Message 5 of 16
(21,041 Views)
Accepted by topic author cmorale4
Hi cmorale4,
Looking at this compatibility article for LabVIEW and DAQmx drivers, If you have LabVIEW 8.5 the latest driver that you can install and use should be NI-DAQmx 9.3 that you can find here.
The best process is to delete all drivers that you have installed so far, you can do a registry clean using CCleaner and then proceed to install version 9.3
steve.bm
AE | NI
Message 6 of 16
(21,027 Views)
hi i too have the same problem i too cant finfd the daq icon in the pallete. ,,i am using labview 2012 and i tried to intall daq version 9.1.7 and the harware i am using is  NI USB 6009 ..., if the  driver version is the problem what version i have to install and  and whether USB 6009 is compatible with labview 2012 .....and if i want to use the bio-medical tool kit for labview 2008 is it possible ??..please guide me sir..
Message 7 of 16
(19,050 Views)
I'm not finding a DAQmx version 9.1.7.  Even then according to this fancy chart, You need DAQmx 9.5.5 or newer (currently up to 9.8) to work with LabVIEW 2012.  If you don't have the driver disk that came with your copy of LabVIEW, I would recommend downloading the latest version (DAQmx 9.8).
There was never a LabVIEW 2008.  Do you mean 8.6?
GCentral
Message 8 of 16
(19,026 Views)
So what problems do you have in looking a the compatibility article ?
What version does that say you have to use for LabVIEW 2012 ?
Spoiler
Minimum a version 9.5.5 of DAQmx for LabVIEW 2012
There are on LabVIEW 2008 version, theres is a LabVIEW 8.x
You can not use a tool kit for LabVIEW 8.x together with LabVIEW 2012.
Message 9 of 16
(19,021 Views)
yeah i meant labview 8.0 only..and i have two doubts.!!!
1) Can we use the bio-medical toolkit for labview 8.0 . ( which i downloaded earlier from NI website ( evaluation software)?
2) Whether the NI DAQ driver of version 9.5.5 allows USB 6009 DAQ card to connect with labview??
Thanks...!!!
Message 10 of 16
(19,012 Views)
