can't find DAQ assistant in LabView
@suriguvi88 wrote:
yeah i meant labview 8.0 only..and i have two doubts.!!!
1) Can we use the bio-medical toolkit for labview 8.0 . ( which i downloaded earlier from NI website ( evaluation software)?
2) Whether the NI DAQ driver of version 9.5.5 allows USB 6009 DAQ card to connect with labview??
Thanks...!!!
Why in the world would you want to use LabVIEW 8.0?  That was one of the worst versions ever made.  (seriously, it is the butt of so many jokes for those of us who were around when it came out)  And you said you already have LabVIEW 2012.  Why downgrade?
To use LabVIEW 8.0, you would need a DAQmx version between 8.0 and 8.7.1.  And I don't think the USB-6009 was around during those versions, so you might lose support for it (I could be wrong).
My advice is just keep with LabVIEW 2012.  There is a Biomedical toolkit readily available for LabVIEW 2012.
GCentral
Message 11 of 16
(2,737 Views)
ok....my question is.. whether  USB 6009 DAQ card can be used with driver vesion 9.5.5 ( labview 2012)???
Message 12 of 16
(2,733 Views)
Straight from the manual for the USB-6009:
The following references to documents assume you have NI-DAQmx 9.3 or later, and where applicable, version 8.5 or later of the NI application software.
So, your answer is YES.
GCentral
Message 13 of 16
(2,722 Views)
So if you do a little work and search for your product and a support drivers you will get this page:
NI-DAQmx and NI-DAQ Driver Support: Portable Devices
This will tell you that you device can use the 9.6 version of DAQmx driver.
If you the look at the last page, it will tell you that LabVIEW 2012 also supports version 9.6.
So what do you think you should use?
Message 14 of 16
(2,720 Views)
Agreed.  Just using the latest is by far the saftest.  DAQmx 9.5.5 was just the minimum for LabVIEW 2012.  The current version of DAQmx (9.6) will also support LabVIEW 2012.  And you will likely have another 2 years of DAQmx updates that will work with LabVIEW 2012.
GCentral
Message 15 of 16
(2,713 Views)
hi i just downloaded version 9.5.5 for labview 2012 and NI DAQ usb 6009 worked with it ..as well...
thanks for the help!!! 🙂
Message 16 of 16
(2,697 Views)
