can't find daq palette
Hey guys!
I can't find the palette für data acquisition with it's vis (e.g. analog input, output etc.) on the function table.
Using LabVIEW 7.1.
Thank you!
(2,896 Views)
Did you install DAQmx?  It is not installed with LabVIEW, it's a seperate CD.  I'm using DAQmx 8.0.0 with LabVIEW 7.1.
Patrick.
(2,884 Views)
Yes I installed DAQmx. The problem is, that I do find all the DAQmx-VIs like "create virtual channel" etc. But I can't find the "traditional" DAQ-stuff like "analog input". I can't even find the symbol for the whole palette on the function table.
(2,871 Views)
You need to install traditional NI DAQ device drivers for that.
If you do not have it on a CD, You can download the latest version of Traditional NI DAQ from here
You can find current versions of Multifunction DAQ device drivers from here
(2,867 Views)
Thanks, that was very helpful - I would have searched for days for those links!
Thanks Smiley Very Happy
Gouvi
(2,864 Views)
